4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#60386 05/12/2006 1:21 PM
Junior Member
Junior Member
I need to know if a TH350 will bolt to a 235 and if so what type of adapter, flexplate, starter, and shifter is recommended........Thanks
Socket Breaker
Socket Breaker
Yup.
dunno about the details though.
You might try the 'search' function.
-W
Almost as good as the search function, try looking at the tech tips and faq, it will answer all kinds of questions.
http://www.stovebolt.com/techtips/trannyswap2.htm
A 1965 Chevy C-60 2-Ton Flatbed
A 1953 Chevy 1/2-Ton
A 1949 Chevy Business Coupe
Here's another: Bendtsen\'s . But to answer the basic question the THM will only go on the back of a 235 (216, 261) with an adapter.
Professional Novice
Your in luck, a small outfit by the name of General Motors just happened to make such an adapter. The best place to find them is on pre 63 chevs with the 235 and cast iron powerglide. It seems that more 61 and 62's were bought with glides than previous years--I guess drivers were getting lazy.
Evan
The non-smart a$$ answer is that there are a few problems with putting a TH350 of 700r4 behind a 235/261:
First, auto's need a flex plate, not flywheel- No big deal to get one of these.
Second, motor mounts- When you ditch the bellhousing you'll need to figure out how to mount the engine. Some outfits do make a piece that'll bolt where the bellhousing was and provide mounts. There are probably some other options too.
Third- shifter- you should be able to work this one out- I like the TH350 shifter that sticks up through the floor like the original 4-speed shifter- keeps the inside stock looking,which I like.
Fourth- You may need a bigger radiator and definately will need to install a tranny fluid cooler.
Stovebolt engine co has a kit for putting the TH behind a bolt. I've read they get it from Buffalo and you can get it from the supplier for less= you'll have to figure that out for yourself.
