1 members (wilbur53), 92 guests, and 2 robots.
Topics128,195
Posts1,057,374
Members48,469
#602752 12/19/2009 11:05 PM
I have the 1934 207 c.i. engine running. A horrible clanking sound in the front end after trimming the engine, though. I adjusted the tappets and oiled the top end. The sound is somewhat periodic. Any ideas on what it might be?
MMMM, somewhat periodic sounds like a babbit rod chattering. Do you notice it when you give it gas.... or let the engine rpm's level out and then accelerate or come off the gas totally?
Those old babbits will rattle ....sometimes for a looooong time before they bite the dirt.
Hope its not this but could be.
Its been a long time since I worked on a 207 and I don't remember the water pump set up.
Could be a bent push rod hitting the side cover.
I acquired a set of reconditioned rods for that engine recently. I won an Ebay auction for a set of "235" babbited rods that ended up being described incorrectly. Drop me an IM if you think you need them.
On a 216, that sound can come from a sticking valve causing a pushrod to bounce around because of excess clearance. On your motor, I believe that there are springs on top of the lifters and I don't know how it sounds if one of them fails.
1951 1 Ton Completed
Apprentice
Apprentice
How did this turn out? Did you figure it out yet?
dsorb #605604 12/30/2009 11:18 PM
Had the valve cover off. The rockers are adjusted corectly and no stuck valve, although the #1 intake still looks fishy. The push rods all look fine. Hate to think it's the babbits.
