0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 25 | I have the 1934 207 c.i. engine running. A horrible clanking sound in the front end after trimming the engine, though. I adjusted the tappets and oiled the top end. The sound is somewhat periodic. Any ideas on what it might be? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | MMMM, somewhat periodic sounds like a babbit rod chattering. Do you notice it when you give it gas.... or let the engine rpm's level out and then accelerate or come off the gas totally?
Those old babbits will rattle ....sometimes for a looooong time before they bite the dirt. Hope its not this but could be. Its been a long time since I worked on a 207 and I don't remember the water pump set up. | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | Could be a bent push rod hitting the side cover. | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | I acquired a set of reconditioned rods for that engine recently. I won an Ebay auction for a set of "235" babbited rods that ended up being described incorrectly. Drop me an IM if you think you need them. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | On a 216, that sound can come from a sticking valve causing a pushrod to bounce around because of excess clearance. On your motor, I believe that there are springs on top of the lifters and I don't know how it sounds if one of them fails. | | | | | Joined: Feb 2009 Posts: 5 Apprentice | | Apprentice Joined: Feb 2009 Posts: 5 | How did this turn out? Did you figure it out yet? | | | | | Joined: Oct 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 25 | Had the valve cover off. The rockers are adjusted corectly and no stuck valve, although the #1 intake still looks fishy. The push rods all look fine. Hate to think it's the babbits. | | |
