1 members (baldeagle),
34
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60218 05/08/2006 1:06 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | The Edelbrock carb on my truck seems to loose the fuel when it isn't driven for a week. The fuel tank has been relocated in the rear and a new hi vol pump installed. I still have to crank it for 10-15 sec, to get the fuel up. the carb is fairly new. | | |
#60219 05/08/2006 2:21 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Dunno anything about how the Edelbrock is plumbed, but I had that problem with my Carter W-1. (Cranking 10-15 secs)
I just rebuilt it, and it fires on the first crank now. Runs smoother, too.
Is the new fuel pump electric? If it is, try turning on the key, pumping the gas pedal a few times, and then try starting it. | | |
#60220 05/08/2006 4:24 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I had this happen on my old 63 Nova with either an Edelbrock or Demon carb. The problem seemed to be the Edelbrock fuel pump. I don't think there's any anti-drainback valve in it. I never did check into the possbility of installing a valve like that between the tank and the pump, but it seems like it otta work. I don't know of any sources for such a valve, tho. | | |
#60221 05/08/2006 10:21 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | The fuel pump is a brand New Holly Hi-performance type. don't know the number right now. | | |
#60222 05/08/2006 10:43 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That is a pretty common problem with the AFB (Edelbrock performer) carb. If it is going to set for periods of time I put an electric fuel pump back by the tank with a switch under the dash. Turn on the switch for a few seconds & it kicks right off. A spring return switch works best. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#60223 05/10/2006 9:49 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | If I put the electric in, do I eliminate the old pump? | | |
#60224 05/10/2006 10:56 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. Just use the electric pump to prime it. The mech. pump will pull right through the electric pump. Be shure to put a filter in front of the electric pump & mount it low along the frame & near the tank. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#60225 05/11/2006 1:13 PM | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | Gazim, It sounds like a lack of fuel problem to me. Is the choke working, and the accelerator pump in the carbie?
Wombat | | |
#60226 05/11/2006 4:04 PM | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | I think what he is talking about is the carb is drying out over a weeks time. The Quadrajets used to leak the fuel out of the plugs under the main body. Epoxy was a good cure for them. Take the carburater off the truck while its still fule of fuel. Let it set on a bench for the same amount of time it did on the truck and check it for leaks. Could be just a simple plug leaking or it could be just evaporation. The electric primer pump will help it start, but thats not the main problem. The fuel doesn't run back out the carburaters due to the location of the needle and seat. The fuel line my run dry, but the carb should stay full and it should start right up.
Joe | | |
#60227 05/11/2006 4:26 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Thanks Joe, sounds like your advice fits my situation. Will give it a try. can you give me a better discription of where the plugs are. Hate to epoxy the wrong thing  | | |
