2 members (1955 1 Series, Otto Skorzeny), 159 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#601130 12/14/2009 8:37 AM
I am going to swap my engine soon. I do not want to have more power, the only reason is that the 283 engine is worn out.
Are the any kit or parts I need when I want to mount my old manual transmission to the new engine?
'59 Apache
'67 Mustang
no, unbolt the 283, bolt in the 350. they are externally the same. (assuming that you are swapping Generation 1 for Generation 1 engines)
You will need to reuse the bellhousing, flywheel, clutch, pressure plate, and starter from the 283. All these parts should bolt onto the 350 without a problem, as long as the 350 is a pre-91 engine, IMHO.
Before you put the new engine in, check that the starter bolt holes line up. There is a possibility of needing to drill and tap a new hole. THis works a lot better when the engine is out of the truck.
Check see if the 350 has a pilot bearing. Probably wouldn't hurt to install a new one even if it did, since you have it apart.
Brian
1955.2 3100 Truck
His starter will bolt into the bellhousing, not onto the block. That's the reason for using the early parts, since the block-mounted starter will not clear the early-style bellhousing with the 3-bolt starter nose cone bolted into the bellhousing, and it's going to be needed for the rear engine mount with the crossmember under the bellhousing.
When I swapped the 350 in place of my 283 on my old '63 C10 I just did what Jerry said to do and had zero issues. It was a straight swap in.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
