| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59954 05/02/2006 8:10 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Just curious-is it possible to use an HEI distributor in a 6 volt truck? I'm trying to make this truck drop dead reliable for the owner but he's adamant about keeping it 6 volt. I guess if the HEI isn't an option I can go with the Pertronix set up. Speed | | |
#59955 05/02/2006 5:02 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I don't think you can do it- HEI requires 12 volts.
#59956 05/02/2006 9:56 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Nope, no HEI for him, on the other hand, points are extremely reliable if you know how to set them, all you have to do is keep an extra set in the glovebox. Maybe you can teach him how to set points (give a man a fish... teach a man to fish). | | |
#59957 05/02/2006 10:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don,t think petronics has a 6 volt system either. 4.3 is right though. We used points for 60 years. Be shure to put a tiny pinch of grease on the dist cam & replace them every 10k miles.I can,t imagine wy the guy won,t go for 12 volts. The battery is under the floor. When he hits the starter & it starts in a split second he would be impressed. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#59958 05/02/2006 10:29 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There is a Pertronix 6v system for positive ground (GMC) and negative ground (Chevrolet) 6 cylinder engines. I have been running one in my 6v Suburban for over two years. It used to be listed in their catalog and the part number was posted here a couple of time.
On a 6v system, make sure your battery cables are at least 1 or 1/0 and the starter and engine spin just fine. I now have 2/0 (00) cables for the positive cable (to the starter) and the negative ground cable (to the frame behind the battery box, but some people run a long ground cable from the battery to the bottom attachment bolt for the starter).
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=007101 1167N6 1941-1953 216/235 6v negative 1168N6 1954-1962 235/261 6v negative
Tim | | |
#59959 05/03/2006 3:52 AM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | Just to add another vote, HEI DOES require 12 volts. That's why the ballast resistors or resistor wires have to be removed when converting a 12v points iginition to HEI.
But Tim's right. Pertronix does make a 6v unit...and that's the route I'd go. But keep a spare one or the old points in the glove box, just in case. I always carry a spare HEI module with me cuz ya never know when they'll fail. Thay don't fail all that often, but when they do, it's usually at a very inconvenient time or location. | | |
#59960 05/03/2006 5:07 PM | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | And, Unlike points, they don't start to wear out; they just go from working to not working. Because it is an electronic system not a mechanical one, it either works or it doesn't, no sort-of works.
58 Fleetside, 235, "The Old Buckin' Bronco"
#59961 05/03/2006 5:57 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | As far as reliability goes, I've only driven 70's cars for transportation (currently 77 Nova) for the last 25 years and I've only had the modual go on me once.Lucky for me it was in my driveway. It drove home perfectly well, but when I went to restart it,nothing..............Lucky I've always got a spare everything around, so I was not even late for work.  | | |
