1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hello, I was looking at an AD truck today with a grill guard. The inner bracket are welded to the chassis, is that normal? Or should the grill guard be attached with bolts and not welds? It is a large, probably aftermarket/custom grill guard. Thanks, Chris | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | What do you mean by normal? Was it common?....yes Was it an approved GM accessory.....no. | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | I'm forgetting the name, wasn't there an aftermarket grill guard made in TEXAS? | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | If it looked like this it was a Smash Hit grille guard made by the Perry Company in Waco, TX. No - it is not normal to have it welded to the frame. Mine is bolted to the frame along with the bumper bracket. | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | I should have taken a picture. It kind of looks looks the Smash Hit grill, but instead of being made out of tubing, it is made out of 1/4" x 1 1/2" plate. Thanks, Chris | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | It's not tubing, it's 1" chrome bar stock. They used to call them cow pushers.  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Chris, just a guess but that looks like a home made one. Lots of folks used the flat metal and built there own to their liking. Just my opinion. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Check out my 53 with a factory accessory guard, total bolt on! | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Achipmunk, I would think that it is home made from the photo as well. It could be, but the photo does not show, very well, the way that the guard is curved to fit the truck. If you look at the photo closely you can see how the bottom is curved down in the center, and the whole guard is curved back on the sides. So if it is one of a kind, it was made by a skilled metal worker in a very well equipped shop. When you look at it, it appears to be professionally/factory made. My feeling is that it is not one of a kind. Chris | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Different styles of grill guards were available in different Advance-Design years. Here are some from 1954. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | And impressively enough, the Perry Company in Waco Texas is still in business. | | |
