8 members (Gdads51, frogfarmer, Hotrod Lincoln, rfs56trk, JoeDude, Jon G, TexasA&M48Truck, dt235sd), 139 guests, and 3 robots.
Topics128,038
Posts1,055,536
Members48,425
#599217 12/08/2009 4:09 AM
Hello,
I was looking at an AD truck today with a grill guard. The inner bracket are welded to the chassis, is that normal? Or should the grill guard be attached with bolts and not welds? It is a large, probably aftermarket/custom grill guard.
Chris
...not normal
Achipmunk #599242 12/08/2009 5:31 AM
What do you mean by normal? Was it common?....yes Was it an approved GM accessory.....no.
crenwelge #599253 12/08/2009 6:02 AM
I'm forgetting the name, wasn't there an aftermarket grill guard made in TEXAS?
If it looked like this it was a Smash Hit grille guard made by the Perry Company in Waco, TX. No - it is not normal to have it welded to the frame. Mine is bolted to the frame along with the bumper bracket.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #599307 12/08/2009 2:17 PM
I should have taken a picture. It kind of looks looks the Smash Hit grill, but instead of being made out of tubing, it is made out of 1/4" x 1 1/2" plate.
Chris
It's not tubing, it's 1" chrome bar stock.
They used to call them cow pushers. grin
David Colter
54TOW #599532 12/09/2009 2:20 AM
Here's my new grill guard. http://home.comcast.net/~chriseye/images/grillguard.jpg Anyone know who made it?
Chris
Chris, just a guess but that looks like a home made one. Lots of folks used the flat metal and built there own to their liking. Just my opinion.
Achipmunk #599607 12/09/2009 5:03 AM
Check out my 53 with a factory accessory guard, total bolt on!
1946 1/2-Ton Chevy
Achipmunk,
I would think that it is home made from the photo as well. It could be, but the photo does not show, very well, the way that the guard is curved to fit the truck. If you look at the photo closely you can see how the bottom is curved down in the center, and the whole guard is curved back on the sides. So if it is one of a kind, it was made by a skilled metal worker in a very well equipped shop. When you look at it, it appears to be professionally/factory made. My feeling is that it is not one of a kind.
Chris
Different styles of grill guards were available in different Advance-Design years. Here are some from 1954.
54TOW #600177 12/11/2009 3:31 AM
And impressively enough, the Perry Company in Waco Texas is still in business.
