1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#59843 04/29/2006 12:41 AM
I'm looking at the nv 4500 for a swap in my 1940 gmc. Some of these transmissions come with an electronic sender in the tail housing... these would be the gm models which have a shorter tailshaft. 4 wd models rely upon the speedo gear in the transfer case.
Is there any way to overcome the electronic speedo problem to make the old mechanical guage work?
#59844 04/29/2006 12:56 PM
#59845 04/29/2006 1:23 PM
will this work with a T-5? ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#59846 04/29/2006 4:49 PM
Been using an Abbott Box Cable X Converter for a few years on my electronic speedo T-5 conversion. Mounts under dash and drives the old mechanical speedo. It is fully adjustable to get speed right! Unit runs about 300 bucks. Can order direct or go through a Speedo Shop. Nevada Speedometer in Sparks, NV is in the know (tech support!) and where I ordered mine from.(775-358-7422). http://www.atrol.com/cablex.htm
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
#59847 04/29/2006 7:42 PM
cool! good to know there are options. do these units hold up well to daily driving?
#59848 05/03/2006 5:54 AM
My box has performed flawlessly for over 3 years. Once wired and all the dip switches set it is maintence free and right on accurate. You may hear a faint wine from electric motor that drives the speedo cable but is barely noticable and only when moving. Modern transmission and original restored speedometer and it all works great!
#59849 05/03/2006 2:59 PM
i sure hope so we b
cause after our 51 is painted i'm installing an electronic sender to a new haneline gauge off the T5 hybrid
keep me posted
Jim & Caroline
