7 members (55shaker, MickeyP, Ranger, KCMongo, Otto Skorzeny, Wally / Montana, Gdads51),
94
0
Mod | | | Forums66 Topics128,051 Posts1,055,706 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59843 04/29/2006 12:41 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I'm looking at the nv 4500 for a swap in my 1940 gmc. Some of these transmissions come with an electronic sender in the tail housing... these would be the gm models which have a shorter tailshaft. 4 wd models rely upon the speedo gear in the transfer case.
Is there any way to overcome the electronic speedo problem to make the old mechanical guage work? | | |
#59844 04/29/2006 12:56 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#59845 04/29/2006 1:23 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | will this work with a T-5? ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#59846 04/29/2006 4:49 PM | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | Been using an Abbott Box Cable X Converter for a few years on my electronic speedo T-5 conversion. Mounts under dash and drives the old mechanical speedo. It is fully adjustable to get speed right! Unit runs about 300 bucks. Can order direct or go through a Speedo Shop. Nevada Speedometer in Sparks, NV is in the know (tech support!) and where I ordered mine from.(775-358-7422). http://www.atrol.com/cablex.htm
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
#59847 04/29/2006 7:42 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | cool! good to know there are options. do these units hold up well to daily driving? | | |
#59848 05/03/2006 5:54 AM | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | My box has performed flawlessly for over 3 years. Once wired and all the dip switches set it is maintence free and right on accurate. You may hear a faint wine from electric motor that drives the speedo cable but is barely noticable and only when moving. Modern transmission and original restored speedometer and it all works great!
#59849 05/03/2006 2:59 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i sure hope so we b cause after our 51 is painted i'm installing an electronic sender to a new haneline gauge off the T5 hybrid
keep me posted
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
