0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#59762 04/27/2006 4:39 PM
I am just beginning to restore (first time)my '48 1/2 ton truck.
My question is when I begin the engine work will I find babbit bearings?
#59763 04/27/2006 5:22 PM
yup
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#59764 04/27/2006 6:14 PM
Kip's short answer is correct. If you need bearing work done, you might find a restorer who can still pour and rework babbitt bearings, or you can find a shop that will machine your rods for inserts. Check other threads here, and use the search feature. Lots of info available.
Good luck.
#59765 04/27/2006 6:53 PM
Ex Hall Monitor
Ex Hall Monitor
You can get a lot more mileage out of your engine if you use aluminum pistons when you rebuild your engine. The main reason the babbit goes bad is the inertial forces caused by the heavy pistons. I talked with a 39 owner who uses babbeted rods and drives 70 mph regularly with no damage because he put in aluminum pistons. I bought a set of .030 over aluminum pistons that I'm going to use when it's time to rebuild my 38.
#59766 04/27/2006 11:04 PM
I have new old stock connecting rods with the standard size babbet bearing, if that is any help to you, and other NOS parts for that engine.
#59767 04/28/2006 2:40 AM
Make sure your engine is original first. It may have already been replaced once or twice in the last 60 years.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#59768 04/29/2006 1:22 AM
The babbitting on the old style rods is extremely thin, not like some of the earlier motors. To restore the rods, machining for inserts is the best way. I had mine machined for inserts and I replaced the pistons with aluminum ones.
1951 1 Ton Completed
