| | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Today My Son and I cleaned the gas tank on the 53 GMC I just got , it's old school I guess but that is the way we did it. It worked great got all the rust out and now the fuel flows clear and clean , it was full of a real dusty rust before and keep cloging the fuel filter. Some cleaned rocks and a 1/3 gal of mineral spirits and about an hour and a 1/2 of rotator time an it's clean. http://s559.photobucket.com/albums/ss39/sparky52/gas%20tank%20clean/Pete
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hey Pete, nothing wrong with that. As my daddy would say..."thats using your head for something besides a hat rack"!! Looking good. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | I've also heard of strapping it to your tractor tire -- which I may do with my '48's tank (not as long as the in-cab tanks).  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah but, it costs ya more to feed that crank motor there than it would to buy a new tank!
Hey buddy, neat set up, looks like somethin' an old tired electrician might make up.
May be we can load up the Jimmy up with spare parts in September and talk the young'n into following us out to KC in the Jimmy. We'll have a caravan.
Good goin' Pete, I like saving as much of the original truck as I can. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Took her out today not far just to see how she runs , ran good , no rust in glass bowl thats good now I gotto order the new sending unit there was no saving the old one . Also got some of the lights working today .
Thanks all , Pete
PS anyone need a gas tank rotator / cleaner jig the kid don't come with ? | | | | | Joined: Oct 2009 Posts: 39 Apprentice | | Apprentice Joined: Oct 2009 Posts: 39 | I removed the gas tank of our 51,it had been over half filled with gas when it was parked(It sat for about 3 years) As I drained it, the first part of the fuel was "varnished",last part smelled ok.Question:Do I need to go thru the whole process of nuts & bolts in the tank?Or is a good hot steam cleaning sufficient? Thanks Joseph | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Take a look inside and see what it looks like,take the sender out , mine had alot of loose rust in it so I had to use the cleaning that We did .
Pete | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | redsoldblue51, although it might not be necessary or overkill I think it is well worth the money to clean and put the liner stuff in it. I have done several and they still are good after 10 years..... and yes, I learned the hard way. I cleaned several and yet ended up some time later on the side of the road changing fuel filters... Just my .02 and its better to be a penny wise than a pound poor. | | | | | Joined: Oct 2009 Posts: 39 Apprentice | | Apprentice Joined: Oct 2009 Posts: 39 | Good advice.Any specific brands? | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | many here will recommend RedKote.... It's what I used, it's only been in the tank for about 4 months now, so no word yet on how well it worked for me. I decided to use it because every radiator shop in town that does gas tank work uses it, and all say that they had good luck with it.
What ever you decide to use...FOLLOW THE DIRECTIONS TO THE LETTER!!!! and make sure that tank is BONE dry before you dump in the liner.
PM me if you have any specific questions.
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... I didn't say it above but I have used he POR15 kit. I did my 37 back in 1999 and its still holding up as well as some others. I can see inside my 37 tank and it does still look good. | | | | | Joined: Mar 2009 Posts: 21 Apprentice | | Apprentice Joined: Mar 2009 Posts: 21 | I just recently cleaned my tank out. First took it to a machine shop to get hot tanked. then putt a couple feet of chain on the inside and some water and shook it out until there were no more rust particles and the water was clear. Let it dry over night inside. Then rinsed it out again with Mineral spirits. Then I used the gas tank sealer that is for sale on Classicparts.com. Worked great! Now the inside of the tank is new and I put a couple coats of paint on it and it looks brand new! Hope this helps | | | | | Joined: Oct 2009 Posts: 18 New Guy | | New Guy Joined: Oct 2009 Posts: 18 | Really neat setup for cleaning the tank! I have one from a '53 3600 I should do, plus a tank from a tractor. However, my youngest son is a little past the stage where he would think cranking the tank for an hour or more would be fun - I have to think of a way to trick him into it . . . | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Do You need to rent a Youngest Son ? But You got to keep Him for a week . He is helping fix up the GMC.
Pete | | |
