1 members (klhansen),
126
Mod | | | Forums66 Topics128,131 Posts1,056,726 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Wow am I have problems getting my hood to fit...has anyone got a suggestions or is there any manual on line I can get a hold of...thanks in advance
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You can shim up the radiator support and shift it left or right until the hood fits. Also the body may be off center with the frame making the hood not fit. Keep it all loose until you get it right. | | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi: What is not fitting on the hood?...front to back or how it lines up on the sides? Brian | | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | the front driver side strikes near the top of the rad support...and I seem to have to pull to hard to get it near on...thanks
