3 members (Peggy M, Ponchogl, treegrower), 72 guests, and 4 robots.
Topics128,099
Posts1,056,508
Members48,448
Wow am I have problems getting my hood to
fit...has anyone got a suggestions or
is there any manual on line I can get a
hold of...thanks in advance
1946 chevy 1/2 ton panel
1937 ford coupe
You can shim up the radiator support and shift it left or right until the hood fits. Also the body may be off center with the frame making the hood not fit. Keep it all loose until you get it right.
1946 1/2-Ton Chevy
old truck heaven
old truck heaven
Hi:
What is not fitting on the hood?...front to back or how it lines up on the sides?
Brian
the front driver side strikes near the top
of the rad support...and I seem to have to
pull to hard to get it near on...thanks
1937 ford coupe
