| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59569 04/24/2006 2:37 AM | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Putting my coil and distributor on today- realized that I can't mount the coil upside down like it's supposed to be (original). It gets in the way of the cap and plug wires. Could I be doing something wrong? I'm thinking the newer cap and coil the previous owner put on were a different size. | | |
#59570 04/24/2006 3:42 AM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | On pre-50? at least I think its 50... The cap and rotor are taller then on the 51 and newer. Mine was upside down but it barely fit so I just flipped it over.
The cap and rotor look to be the same except for the height. The older is about an 1 1/2" taller then the newer style. | | |
#59571 04/24/2006 4:05 AM | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The coil on my 235 is not directly over the distributor. It is positioned to the rear of distributor a couple of inches. Are you sure you are using the correct mounting holes? Also, I think the book calls for some sealer on the 2 mounting bolts.
-Tom
1950 Chevy 3100 w/ 1956 235
