Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall), 54 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#59569 04/24/2006 2:37 AM
Putting my coil and distributor on today- realized that I can't mount the coil upside down like it's supposed to be (original). It gets in the way of the cap and plug wires. Could I be doing something wrong? I'm thinking the newer cap and coil the previous owner put on were a different size.
#59570 04/24/2006 3:42 AM
On pre-50? at least I think its 50... The cap and rotor are taller then on the 51 and newer. Mine was upside down but it barely fit so I just flipped it over.
The cap and rotor look to be the same except for the height. The older is about an 1 1/2" taller then the newer style.
My 1953 Chevrolet
1947.1 Gallery
#59571 04/24/2006 4:05 AM
The coil on my 235 is not directly over the distributor. It is positioned to the rear of distributor a couple of inches. Are you sure you are using the correct mounting holes? Also, I think the book calls for some sealer on the 2 mounting bolts.
-Tom
1950 Chevy 3100 w/ 1956 235
