3 members (Tiny, Otto Skorzeny, 1 invisible),
118
Mod | | | Forums66 Topics128,142 Posts1,056,476 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 456 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 456 | I was just looking through some old 41-47.1 literature and the big bolt front sheetmetal looks identical to little bolt sheetmetal. I know the AD trucks have different front ends, but are Art Deco trucks the same?
I scanned many, many pages from the archives and found no scoop there. Sorry in advance for my ignorance.
George | | | | | Joined: May 2001 Posts: 115 'Bolter | | 'Bolter Joined: May 2001 Posts: 115 | Most of the front sheetmetal is identical. Though the front fenders are cut differently for the larger wheels/tires.
Brian D
| | | | | Joined: Mar 2005 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 76 | | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Only sheet metal that's the same is hood, grille. Fenders are ALL different, even the panel under the grill is different. Have seen lots of half tons with 1 ton fenders, you'll know one when you see one! | | | | | Joined: Apr 2007 Posts: 456 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 456 | Thanks guys. The reason I asked was that I was overlaying drawings from the Chevrolet service manual of the 1/2 ton through 1-1/2 ton and the fenders are exactly the same. Even the radius of the wheelwells.
Thanks again, George | | |
