| | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | I am sorry if this is a dumb question, but I have an Impact wrench that I used this morning, and danged if I dont know how to put oil in it. The book says oil it, and I can clearly see the small area on the handle where the oil goes in, but I cant just push in on that and add oil because it wont push in.
How do I do oil this thing? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I just put a couple drops in the air intake on mine every couple days. cheap HF units. | | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | I oil mine the same way, a few drops before I connect the air hose and its good to go. One thing I found out is if you put to much oil in be prepared to have blown all over the place. I normally hold a rag loosly over the exhaust and hit the trigger for a few seconds to blow out any extra oil.
Gary, Kelly, and Family
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...mine has a small set screw I take out and drop in a few drops...but as someone said, just put some in the air intake and it'll find its way to the right place..... It will probably spit oil out for a while depending on how much you put in it. Usually about 3-4 drops once a week is ok unless you use it a LOT then do it two or three times a week. | | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | We have oilers with sight glasses on the lines we use for pneumatic tools. This is the easy way, and about the only way for grinders and stuff that run at high speeds for a long time. Also, If you have a steady mist, you don't have the oil come out right at first and they have a film of oil when you put them up. This is especially important in high humidity near the dew point where metal sweats. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Go with two to three drops before using it each day. | | |
