1 members (baldeagle), 22 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#592416 11/14/2009 3:26 PM
Apprentice
Apprentice
I finally got my 1962 longbed on the road and am having a blast driving it ! It has a 235 from a 55 car and a 57 3 speed from a truck ( no laughing ) THe only upgrade I would like is another trany, maby a t -5 . What is the best option for this (do it your selfer).
Hello Rick. If you'll do a search on transmissions or transmission swaps, etc. I think you'll be surprised at the amount of info we have available. It is a very popular subject here. A lot of it will be for the AD model but well worth your time to check out. Thanks and Welcome Aboard Rick.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #592529 11/15/2009 12:41 AM
Rick,
How about a rear end swap instead? What ratio are you running? A different rear end would be pretty easy. Are you looking for more gears or more speed?
Apprentice
Apprentice
I don't know what rear end I have , but I have a comfortable top speed of about 45-50 and bad gas milage . I am open to any and all suggestions . I heard it was gard to change the gears in the rear end ?
I did the t5 swap and I love it. The bottom end is good and highway speeds are a breeze.53 moneypit has the right idea, just search on here and inliners- you'll find more than you need.
Dustman #592710 11/15/2009 6:08 PM
Apprentice
Apprentice
dustman did you have to change your flywheel or driveshaft , and what did you take your T-5 from ? Thanks!
rick tool #593329 11/18/2009 12:24 AM
your 57 truck bellhousing should work, mine was a 55. I used the pressure plate and flywheel from the truck tranny, with a cluch disc for an s-10 (thats where the t5 came from. You have to cut the pilot shaft and piece the throwout bearing slides on. This used to be a torque tube, so I used a modern rear and shaft. I had to shorten the shaft.
Dustman #593332 11/18/2009 12:33 AM
http://www.inliners.org/
check this out, there is lots more info online, just look. I did mine two winters ago, so I can't remember were it was, some sites had pictures, some were all text.
Dustman #593334 11/18/2009 12:46 AM
Apprentice
Apprentice
Thanks for all the great feedback , my confidence is rising ! Your help, combined with my adventure yesterday confirmed to me that this is the right fit for my truck and me. I drove my truck on hwy 75 from dallas to vanalsten tx. yesterday ( about 50 miles one way ) and by my best calculations I was getting about 8 yea 8 mpg ! I was keeping it at about 55 mph and though it was running strong it was really roaring !
