6 members (Samantha, tclederman, TUTS 59, Otto Skorzeny, Mike Roache, Steelonsteel), 48 guests, and 4 robots.
Topics128,036
Posts1,055,458
Members48,422
#591592 11/11/2009 2:08 PM
Please help a newbie: I have what I believe is a 1955 235 engine in a '53 3600 truck (the engine model is F55Z, and the engine block is a 3836233). The bottom of the flywheel is exposed - there must be a missing flywheel cover that should be there?
Are these covers available from one of the suppliers (I haven't found one yet), or is it possible to find one from salvage yards? Are they sheet metal, or a casting?
Thanks for any help.
1960 LCF 60
1968 TE50 Tilt-Cab
Apprentice
Apprentice
Yeah I have one for my 1960 235 and it is held on by just 2 bolts into the bell housing. It is just sheet metal. Its a common enough piece that I think lmctruck.com, Jim Carter old chevy parts, or even classictrucks.com should have one for you. Those places may charge you more than a junkyard though. Hope this helps.
Also try www.obschevy.com for NOS part or EBay where they often appear.
Drew
Your engine is from a '55 passenger car with manual transmission.
Bill Burmeister
Thanks, guys, for the help. I will get a cover now that I know what I am looking for and where to find it.
Is there any difference between 235's that were originally in a passenger car rather than a truck, or is an engine just an engine?
1960 LCF 60
1968 TE50 Tilt-Cab
In my experience,there was no difference.
Drew
There are actually two pieces to this assembly one that goes against the flywheel on the block side and the inspection cover underneath see pictures they attach with 1/4" stovebolts. This cover was often one of the first things removed/lost on these old trucks.
http://good-times.webshots.com/photo/2236263090102454676KlPtZc
http://good-times.webshots.com/photo/2938675320102454676lzIOOW
I know that the early '50's covers are different between a car and truck. I needed a replacement for my '50 Car and got one for a pick-up and it was different.
