| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | Hey guys, I'd like to remove the hubs from my drums. I don't see any rivits holding them together, and was wondering how to do it. Rather than beating on them and breaking something I thought I'd ask the experts! Thanks...Jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Without seeing how they are put together, I can only make a guess at what you need to do. There's a possibility that you may have to press out the wheel studs to remove the drum. Some are held on that way.
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | Thanks longbox, I hadn't considered that.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you can also whack them out with a hammer. put the nuts on unil they are flush with the top of the stud, remeber flush so when you whack it with the hammer you are hitting them both squarely athe same time this way you do not screw up the threads on either one as you have to take the nut off to get it apart ron | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you do go the hammer route, use a brass hammer. A steel hammer, even if you put the nuts on, may damage the threads.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Hold the softer hammer on the studs and hit it with a bigger hammer. Joe | | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | Got the hubs apart today with a press. Gave that chi-com press quite a workout. Glad I didn't have to hammer them, cause they were tight! Thanks for all the tips....BTW, Joe H got any pics of that 3 carb setup? Does it perform good? I'm putting a 250 in my 40 and just picked up an Offy intake with 3 carbs, just wondering what to expect.
| | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | great tips! flush nuts, brass intermediate. i just ruined some threads on something else by non-flush, steel hammer method | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you can always make a few different drivers for removing these kind of studs and for strg ends Take about a 2 or 3" section of 1" hex and drill it and tap it about 1/2" deep with corresponding thread and put it on until it bottoms and then give it a good whack with a hammer,done there are so many cheap tools out there now albeit"china" and if they are avail locally you can buy them. lots of them don't last that long, so they are ok for home use as you may mever use them again ron | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | i follow you padre if i think 1" square or round, but, 1" hex? what's that? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | All hex nuts and hex headed bolts come from hex bar stock. One of my friends has a machine shop with a number of automatic screw machines and has hex bar drop offs from 3/16 to 2.5 inches in brass, aluminum, steel, and stainless. The drop off is the last bit of bar that won't chuck up in the collet and feed so it is scrap. I get several of each size from him and use my lathe to make bolts not readily available from most fastener places; stuff like some convertible top bolts or bolts with a long shank and just a few threads on the end, or something as common as hood arm shoulder bolts.
Evan
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | What was available would be my guess. Anything you can drill and tap would be ok. The hex might be easier to thread on but I doubt it. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I beg to differ, coilover. While large hex nuts and special bolts certainly are made from hex stock, most standard bolts and screws are made from round stock and "cold headed"...a forging process that makes a strong, accurate, CHEAP head (hex, socket, phillips, countersunk, etc.). It's all about mass production and minimizing waste. If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
