| | | Forums66 Topics128,100 Posts1,056,514 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | I've used a home-brewed bracket that fits over the end of the axle, with a 10-ton Porto-Power ram for a pusher. When the pin moves, it will occasionally launch itself like a rocket, so don't get very close to the axle while you're pushing on the pin. That 10-foot high pressure hose on the Porto-Power is just about the right "safe" distance for me. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | i'm going elementery with a bottle jack | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I think I am going with the local machine shop. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | That ought to work for about 90% of them. C-clamp was a great invention. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Local machine shop will do'em for fifty bucks plus parts, I think thats the way to go. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes most any shop can press them out. But can they do it when the axle is still in the truck? A hydraulic and portable king pin press can, that's what this thread is about.
I think it's fairy obvious that you can simply take the whole axle to a shop to press them out... if you have the axle out of the truck.
Grigg | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It should also be obvious that removing the axle and having the work done safely may have considerable merit. When you talk about rocketing things off a gargage floor you may want to consider alternatives. Home made tools are exactly that home made and carry inherent risks from any standpoint. If you are that far into a rebuild and you are not removing the axle/u-bolts now some 55-60 years old again it begs the question why, you can buy a whole new set of 4 for $32 bucks, anybody price dental work or surgery lately? | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Nice work Rednate....I like your style!
Hank | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I once visited a fella that made an adapter for his hydraulic wood splitter and used that to install pins and bushings. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Watch the Red Green show. He has an adapter
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | A couple of nice lookin tools for sale there.But how many people are gonna spend that kind of money for a tool they may only use one time.I realize a professional can justify spending that kind of money,but for me the C clamp looks pretty good,and reasonably priced.One thing that has not been mentioned here is heat,for removing king pins. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Looks like that C clamp will also do U joints, now you have a multi-tool. | | |
