4 members (Wally / Montana, tclederman, Donf, cmayna), 91 guests, and 2 robots.
Topics128,086
Posts1,056,101
Members48,434
#58816 04/05/2006 9:09 PM
Hey Bolters,
Just returned from pick and pull empty handed,I found a t-5 in 88 s-15 GMC.Proceded to harvest it,pulled 4 bolts from tranny to bell housing,crossmember,driveshaft,shifter,striped off all the supports, shuold slide right out?Wrong.Comes out About 1/8-1/4 and stops-acts like maybe some kind of retainer or something in the bellhousing,is there? So I proced to pull all the bell housing bolts=bell slids about 1/2 and stops.I don't consider myself to be a amature wrench turner,matter of fact unless it involves having vehicle hooked to computer I do all my own work. I looked this tranny and bell over and over and it is clean should fall out.What am I missing?or do I need a bigger prybar.So anyway it started to rain/snow and I forefit to S-15. Has anyone else ever had this problem,Could the splines on the tranny be siezed to disk? As always Thanks for Help/input
Aaron
#58817 04/05/2006 9:56 PM
Riding in the Passing Lane
That is weird. It could be the splines on the disc or the pilot brg. could be stuck to the trans shaft. The next order would be a larger pry bar.
1972 Chevy c10 Cheyenne Super
#58818 04/05/2006 11:39 PM
that puppy should slip right out...
is the clutch arm /throw out bearing fouling on the bad heavily worn clutch (fingers)??
OR the clutch face might be rusted to the flywheel...
time to get the BFH out
Jim & Caroline
#58819 04/06/2006 3:00 AM
Did you pull the shifter out of the floor?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#58820 04/06/2006 3:30 AM
Yes,pulled shifter,it acts like it hanging up on pressure plate or something inside bellhousing,thats why I was wondering if there is something to retain tranny to bell on the inside of the bellhousing-sounds stupid but i wouldn't put anything past the manufactures on some of the newer vehicles.If there is no retaining device then maybe the input-disk-throwout is screwed up and i better find a different tranny. Thanks for the replys
Aaron
#58821 04/06/2006 7:33 AM
Maybe the pilot bearing is stuck on the input shaft?Clutch hub sticking on the splines?(my best guess) I'd try a prybar on each side between the tranny and bellhousing,and equal pressure on both sides,it'll probably resist,then TWANG-it'll pop loose.Not much you can damage this way...
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#58822 04/09/2006 1:15 AM
Just got back from another junkyard found another T-5.Proceded to pull it same as the first and it came out very nicely,Yea!! So the first one must have had some sort of problem in the bell housing.This one was a little cheaper too,50.00 not bad.The only trouble i have is when i go in thease self service yards i always spot a hand full of other items i gotta have and leave spending a whole bunch more than i planned,funny my wife does the same thing every time she enters a Walmart.Any way thanks for the input and help Aaron
