7 members (Otto Skorzeny, UtahYork, Ponchogl, Lonnie, Bicounty, BC59, JW51),
160
Mod | | | Forums66 Topics128,089 Posts1,056,129 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58816 04/05/2006 9:09 PM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Hey Bolters, Just returned from pick and pull empty handed,I found a t-5 in 88 s-15 GMC.Proceded to harvest it,pulled 4 bolts from tranny to bell housing,crossmember,driveshaft,shifter,striped off all the supports, shuold slide right out?Wrong.Comes out About 1/8-1/4 and stops-acts like maybe some kind of retainer or something in the bellhousing,is there? So I proced to pull all the bell housing bolts=bell slids about 1/2 and stops.I don't consider myself to be a amature wrench turner,matter of fact unless it involves having vehicle hooked to computer I do all my own work. I looked this tranny and bell over and over and it is clean should fall out.What am I missing?or do I need a bigger prybar.So anyway it started to rain/snow and I forefit to S-15. Has anyone else ever had this problem,Could the splines on the tranny be siezed to disk? As always Thanks for Help/input Aaron | | |
#58817 04/05/2006 9:56 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That is weird. It could be the splines on the disc or the pilot brg. could be stuck to the trans shaft. The next order would be a larger pry bar. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#58818 04/05/2006 11:39 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | that puppy should slip right out... is the clutch arm /throw out bearing fouling on the bad heavily worn clutch (fingers)?? OR the clutch face might be rusted to the flywheel...
time to get the BFH out
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#58819 04/06/2006 3:00 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Did you pull the shifter out of the floor? Scott | | |
#58820 04/06/2006 3:30 AM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Yes,pulled shifter,it acts like it hanging up on pressure plate or something inside bellhousing,thats why I was wondering if there is something to retain tranny to bell on the inside of the bellhousing-sounds stupid but i wouldn't put anything past the manufactures on some of the newer vehicles.If there is no retaining device then maybe the input-disk-throwout is screwed up and i better find a different tranny. Thanks for the replys Aaron | | |
#58821 04/06/2006 7:33 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Maybe the pilot bearing is stuck on the input shaft?Clutch hub sticking on the splines?(my best guess) I'd try a prybar on each side between the tranny and bellhousing,and equal pressure on both sides,it'll probably resist,then TWANG-it'll pop loose.Not much you can damage this way... Speed | | |
#58822 04/09/2006 1:15 AM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Just got back from another junkyard found another T-5.Proceded to pull it same as the first and it came out very nicely,Yea!! So the first one must have had some sort of problem in the bell housing.This one was a little cheaper too,50.00 not bad.The only trouble i have is when i go in thease self service yards i always spot a hand full of other items i gotta have and leave spending a whole bunch more than i planned,funny my wife does the same thing every time she enters a Walmart.Any way thanks for the input and help Aaron | | |
