0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#587999 10/30/2009 2:51 PM
Another silly question from the "New Guy". Just wondering where I would find the engine code. Where on the block could/would they be located?? The only number that I've found so far was on the head and it is 3836848. With GM20 underneath it. And is there a website that I could search the engine code out when I find it?? I'm guessing that I could do on the Stovebolt page somehow. Thanks
TW235 #588004 10/30/2009 3:15 PM
I'm not sure what you have but if its a 235 you should look on the little "pad" just beside where the distributor goes down into the engine. There should be number stamped there. Get it and post here on the post and one of these nice bolters will decipher it for you.
You'll probably have to wipe off the grease/dirt to see the numbers.
Achipmunk #588019 10/30/2009 3:55 PM
And if it's a GMC it will have the engine size (228-248, etc) cast in the block on the passenger side. Sure would help if you'd tell us what it is, make, model, year of birth, etc. Some of these guys are very, very good but I don't think any of them are mind readers.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Achipmunk #588049 10/30/2009 5:31 PM
Ex Hall Monitor
Ex Hall Monitor
Yeppers!
Tiny #588073 10/30/2009 7:02 PM
3836848 is a 235 head casting code used from 1956-1962.
Here are locations of the codes.
Here are codes gathered from various locations. In the right column are links to engine serial numbers in documents at Keith Hardy's wonderful website (if a document is available for that year).
Tim
That should read "And if it's a GMC it will have the engine size (228-248, etc) STAMPED in the block on the passenger side."
Cletis #588107 10/30/2009 9:09 PM
Also, the moderator of this forum should know by now that the 848 head is not a GMC.
His response was not very friendly.
I'd say the "new guy" is asking for help so he can determine the
Make, Model, Year of Birth, Ect....
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #588112 10/30/2009 10:20 PM
Thanks guys. I know its a '59 Apache. Just wanted to know the small details about it. Ie. Where, when it was made etc. I'll get those numbers of the side of the block and post 'em up.
TW235 #588193 10/31/2009 1:53 AM
You have a Canadian truck I would presume. I would guess that the Canadian GMCs still used Chev 235 motors in the light and medium duty trucks in 1959. Here is a serial number decoder for your year. It should be part of the VIN tag.
http://www.oldgmctrucks.com/page0185.html
1951 1 Ton Completed
Its actually an American truck from South Dakota. I've already checked the VIN and it gave me the info on when and where it was produced. Still cleaning the caked on oil off the side of the block to get the engine code. Thanks though T'nix.
