9 members (Wayne67vert, DaveV, Phak1, Eisenholtz, Ponchogl, Bill Hanlon, 55shaker, Rusty Rod, TUTS 59),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 11 New Guy | | New Guy Joined: Oct 2009 Posts: 11 | Another silly question from the "New Guy". Just wondering where I would find the engine code. Where on the block could/would they be located?? The only number that I've found so far was on the head and it is 3836848. With GM20 underneath it. And is there a website that I could search the engine code out when I find it?? I'm guessing that I could do on the Stovebolt page somehow. Thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not sure what you have but if its a 235 you should look on the little "pad" just beside where the distributor goes down into the engine. There should be number stamped there. Get it and post here on the post and one of these nice bolters will decipher it for you. You'll probably have to wipe off the grease/dirt to see the numbers. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | And if it's a GMC it will have the engine size (228-248, etc) cast in the block on the passenger side. Sure would help if you'd tell us what it is, make, model, year of birth, etc. Some of these guys are very, very good but I don't think any of them are mind readers. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You'll probably have to wipe off the grease/dirt to see the numbers. Yeppers!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | And if it's a GMC it will have the engine size (228-248, etc) cast in the block on the passenger side. Sure would help if you'd tell us what it is, make, model, year of birth, etc. Some of these guys are very, very good but I don't think any of them are mind readers. That should read "And if it's a GMC it will have the engine size (228-248, etc) STAMPED in the block on the passenger side." | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Also, the moderator of this forum should know by now that the 848 head is not a GMC.
His response was not very friendly.
I'd say the "new guy" is asking for help so he can determine the Make, Model, Year of Birth, Ect....
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Oct 2009 Posts: 11 New Guy | | New Guy Joined: Oct 2009 Posts: 11 | Thanks guys. I know its a '59 Apache. Just wanted to know the small details about it. Ie. Where, when it was made etc. I'll get those numbers of the side of the block and post 'em up. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You have a Canadian truck I would presume. I would guess that the Canadian GMCs still used Chev 235 motors in the light and medium duty trucks in 1959. Here is a serial number decoder for your year. It should be part of the VIN tag. http://www.oldgmctrucks.com/page0185.html | | | | | Joined: Oct 2009 Posts: 11 New Guy | | New Guy Joined: Oct 2009 Posts: 11 | Its actually an American truck from South Dakota. I've already checked the VIN and it gave me the info on when and where it was produced. Still cleaning the caked on oil off the side of the block to get the engine code. Thanks though T'nix. | | |
