7 members (klhansen, 87GN, tclederman, Stovebolt48, Peggy M, baldeagle, 1 invisible),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,666 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58742 04/03/2006 6:31 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have a few early V8's (265 and 283). Whe I search for a replacement rear main seal, I am a little confused. I see some of the classic part dealers mention the replacement for the rope seal mad out of neoprene ($27 to $35). Then I see on my gasket set that it is good for years 1955 to 1967 with only one seal in it. Is there a specific seal to use when switching from rope to neoprene? Or is this just an opportunity to sell the same common seal with a high price? | | |
#58743 04/04/2006 4:14 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I put a neoprene seal in my 235 some years back. No big problem. It had a neoprene seal already so I don't know if it ever had a rope seal. | | |
#58744 04/04/2006 1:29 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Well all of the SBC's had rope seals in them back then. Whether it got swapped out before is obvious. Did you just use the same seal that was in the kit? | | |
#58745 04/04/2006 2:06 PM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | builder, my kit came with the neoprene. I used it on the 235 for a 59, about 2 years ago. So far ok
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | |
#58746 04/04/2006 8:51 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I appreciate the response. I agree that the neoprene seal is the way to go. Both of you that responded are talking about 235's. Can you confirm that the V8 gasket kit neoprene main bearing seal work with a 1958 283? | | |
#58747 04/05/2006 2:10 AM | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Sorry, I can not confirm that.
#58748 04/14/2006 3:09 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | OK, Heres the dope as I have found out. The 1955-1958 small block chevy 265-283 cubic inch motor uses a rope seal. We all new that. The main seal in the later model gasket kits will not even fit. I ordered a seal from Ecklers ($30 something each)that was a rope seal replacement. It comes with a wire that is inserted next to the seal to keep it in its correct position. I don't see a problem with this design, but then again I haven't run the engine yet. When I went to the local parts store, they said they could get one for my engine for $11. When I went to pick it up the package said 1959-1967. It would not fit the early sbc. I had the attending counter computer parts looker upper check out the earlier engines for the same part number. They either had a rope seal or the late model neoprene seal. The years in their computer gave the late model seal number for the 1957s too. So I guess in answer to my own questions are;
1. No, the standard seal in the sbc gasket kits will not fit the early years. 2. The standard gasket kits do not come with a rope seal, and the after market neoprene seal is quite expensive. 3. If the parts guy can read a computer but cannot read a book, your chances of successful cross referencing are slimmer still. | | |
#58749 04/14/2006 3:58 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I wonder why the v8 gasket kits don't include the rope seal,the six cylinder kits do ? A lot of the auto parts stores don't have books.I know mine always has to call the warehouse for older parts.How hard can it be to add the old parts to the computer catalog ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
