2 members (Ponchogl, Otto Skorzeny), 72 guests, and 1 robot.
Topics128,034
Posts1,055,548
Members48,425
#586821 10/26/2009 11:41 PM
I just read an article on the egge machine websight about a stroker stovebolt.What interested me was the addition of theads in the front of the crank for an aftermarket harmonic balancer.Anyone ever done this?
3B Offline
Hy Dustman I drill and tap all the crankshafts of the engines I rebuild, if they aren't already done.
good to hear, I thought it sounded like a good idea. Do you use the stock balencer?
Yes, using the stock balancer is fine.
I drilled mine on the truck with the radiator/grill removed. In the future, when I take a crank in to a machine shop, I'll have it drilled there.
Here's what use on mine.
Tim
Ya probably wouldn't want to go this far out, but at the bottom of the page are a few pixs of how I do mine now. This is a 216 that's in my 1950, 3600.
http://www.pbase.com/dennygraham/tools_of_the_trade
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I wish I lived near Sandwich, IL
lived near Sandwich, IL? i'll say
did you find the crank's steel to be tough on the bits? my cam sure was
I've got to polish the crank so I thought I'd just have the machine shop do it.Unless they want an arm and leg cause mine ar currently in use.Thats a nice little guide you've built Denny!
Do you guys use the stock balancer, or is there a better one you can recommend?
The stock balancer is fine as long as it's not damaged, usually by someone trying to pull it off by the outer ring with a jaw type puller. Simple job to drill the crank, they shouldn't charge you to much.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
