1 members (Hotrod Lincoln),
60
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 76 | does any anyone know who sells them.thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need to be more specific about your heater. Heaters were an option and there were dozens of aftermarket ones used.
I doubt if anyone is reproducing knobs for a specific heater. You'll probably have to find some aftermarket knobs that will work. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | You should be able to get a knob from American Classic or Jim Carter for your 46. As cletis said heaters were a deler option. George | | | | | Joined: Mar 2005 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 76 | i called both and they don't sell them . i have a deluxe heater with and defroster on it just like the one on brads 41-46 Accessories & Options .thanks
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Why not buy a couple of used up heaters, take off the knobs make yard lamps out of the box? | | |
