1 members (Peggy M),
105
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 36 | ON MY 1937 CHEVY 1/2 TON CAB THE FRONT WINDSHIELD WINDOW RUBBER SEAL DOES NOT COVER THE INTIRE WINDOW REVEAL OR OPENING ON THE CAB.AT THE BOTTOM CORNER AND ALONG THE BOTTOM IT DOES NOT PUSH UP AGAINST THE SMOOTH OUTER SHEET METAL SUFACE AS IT DOES ALONG THE TOP EDGE.IS THIS NORMAL?THANKS AS ALWAYS
It's not the speed you travel it's the quality of the trip that matters !!!
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Who did you buy the rubber gasket from???? Most cheap products will give you bad results. Personally I will use only Steele Rubber products, it is the best made stuff I have came across..Joe | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I agree with ZooKeper. I would also BE SURE you have the correct windshield for a 37 cab. The 36 low cab windshield looks just like the 37 winshield. In addition, it is shaped the same, measures very close to the 37 and will bolt up to the 37, but it is not the same windshield. It does not fit correctly.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2000 Posts: 5,232 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,232 | I used three different gaskets before buying one from Steele Rubber. Its the only one that fit correctly and let the windshield close all the way.
Joe
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Another vote for Steeles - tried one from Jim Carter first - rubber so hard it would not flex - ordered one from Steeles - worked like a charm ! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I have a Steele Rubber gasket on my windshield frame and it has been on there since 1982. It looks just as good today as the day I installed it. There really isn't any other choice. It has to be Steel.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jul 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 36 | Thanks to all. I do have steele rubber so I just may have a 36 low cab window frame as 6cylindersovertexas suggested.
| | | | | Joined: Feb 2000 Posts: 5,232 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,232 | There is some adjustment up at the hinges if I remember right. Its not much, but it mmay help to move it around a bit. Joe | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | backn37..... I purchased a NEW frame from American Classis back around 1999 and fits just as you described.... Now I"m wondering if American sent me the wrong one???? ....or sending the same frame for the low cab 36 and the 37??? A fellow just never knows  | | | | | Joined: Aug 2004 Posts: 21 Apprentice | | Apprentice Joined: Aug 2004 Posts: 21 | backn37, what's the height measurement at the center of your window frame ? A 36 is about 11 3/4, while a 37 is about 12 3/4. I have a 37 frame and I need a 36. Send me a PM if you want to do some trading.
| | | | | Joined: Jul 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 36 | My frame has a slight arch across the top 12 3/4" top to bottom at the center.13" top to bottom at the wiper arm .13 3/4"at the end from the top to the lowest point of the curve.It seems 1/2" short all across the bottom. The top arch differs from your description.The frame I have follows the cab line from the inside but not on the outside. Thanks Todd (backn37)
| | | | | Joined: Aug 2004 Posts: 21 Apprentice | | Apprentice Joined: Aug 2004 Posts: 21 | After reinspecting the frames, I see both 36 and 37 frames have an arch across the top. The 36 less of an arch than 37. The frame I believe to be a 37 measures 12 3/4 at the outside center. The 36 I have removed from my cab measures 11 3/4 at the outside center. | | |
