9 members (klhansen, rfs56trk, Bill Hanlon, 1955 1 Series, DHedrick, Otto Skorzeny, 39Master85, greenie-reddy, Peggy M), 136 guests, and 3 robots.
Topics128,087
Posts1,056,399
Members48,442
#578064 09/26/2009 4:15 PM
A guy I know says he has a 64 1 ton with dual wheels and swears it is an all original truck. Were duals available on 1 ton trucks back then, from the factory or did someone change out the rear end to make a flat bed dually out of the truck? Thanks for any info.
Duals were always available from the factory,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Most 1-Tons are Dual Wheel Trucks. The Single Rear Wheel 1-Tons are actually kind of rare.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Duals were even an option on 3/4 tons up to around '72.
Bill Burmeister
Duals were standard from the factory on the '60-'66 Chevy/GMC 1 ton trucks. I am not aware of a single wheel configuration on the 1 ton trucks in those years.
All the guide and the shop manuals show duals as an option. I've seen several single wheel 1 tons from that era. The only years I know of the Chevy/GMC 1 tons had duals as standard equipment were the '94-'00, the big block 454 was also standard equipment in those also. But you could get singles and the 350 as a delete credit option.
Bill Burmeister
