3 members (carbking, 3B, BarryP),
99
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | A guy I know says he has a 64 1 ton with dual wheels and swears it is an all original truck. Were duals available on 1 ton trucks back then, from the factory or did someone change out the rear end to make a flat bed dually out of the truck? Thanks for any info. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Duals were always available from the factory, Scott | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Most 1-Tons are Dual Wheel Trucks. The Single Rear Wheel 1-Tons are actually kind of rare.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Duals were even an option on 3/4 tons up to around '72.
Bill Burmeister | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Duals were standard from the factory on the '60-'66 Chevy/GMC 1 ton trucks. I am not aware of a single wheel configuration on the 1 ton trucks in those years. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | All the guide and the shop manuals show duals as an option. I've seen several single wheel 1 tons from that era. The only years I know of the Chevy/GMC 1 tons had duals as standard equipment were the '94-'00, the big block 454 was also standard equipment in those also. But you could get singles and the 350 as a delete credit option.
