3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57819 03/17/2006 4:30 AM | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | In the last few years, I am seeing a trend by fellows using copper fuel lines in their hot rods.
I like the look of polished cooper...it looks classy with brass fittings and adds a nice touch to an engine bay.
I was always told copper was a bad thing to use for fuel lines.
Is this a myth?
I would appreciate your comments!
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
#57820 03/17/2006 4:45 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | copper is a bad thing to use for diesel or bio-diesel as it will oxydize the fuel, don't know about gasoline
problem I'd consider with copper would be makeing good bends without crimping the flow at all, and making good liquid tight joints that can handle repeated tightening and loosening, as well as exposure to heat - it's regularly used for LPG and natural gas tho
Bill | | |
#57821 03/17/2006 4:52 AM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Copper was used as original equipment for fuel lines on many vehicles through at least the late 1950's.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#57822 03/17/2006 5:55 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | By the end of the 70's and into the 80's, it was discovered that copper could no longer be used as a means to move natural gas. It was discovered that natural gas will slowly deteriorate copper lines from the inside out. You can no longer use copper lines in any kind of construction. The biggest problem with copper is that it is soft enough to fracture if it used in any type of situation where there is movement and vibration of the lines. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#57823 03/17/2006 6:11 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, the buses I started working on thirty years ago [diesel] routinely used copper fuel lines I never experienced a problem with them except where they went through the bulkheads and the grommets deteriorated. | | |
#57824 03/17/2006 6:51 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Joe, that's a suprise - here in Canada copper is common and legal for natural gas in a building - my commercial equipment has been workin fine w/ soft copper drops off black iron distribution lines
Bill | | |
#57825 03/17/2006 7:09 PM | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | Huh...We have a big diesel generator at work with copper fuel lines. It's 1950's vintage though.
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | |
#57826 03/17/2006 7:39 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've been building houses in Texas since 1969 and in the late 70's, or so, we had to stop using copper lines for any drops. All drops had to be done in black pipe and it is still that way today. Copper drops equal a Red Tag. I've even had to change from copper to black pipe on remodel jobs where we weren't actually working with anything to do with the copper. They have made us change it out if they see it! We can use the polyurethane and flex, but no copper. Joe
#57827 03/17/2006 7:44 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | differant grades of copper. Rubs through if moves agaist any thing. compression fitings are tight to 200 lps water pressure. copper looks good. no efect by gasoline that i know of. inspect regulary for problems. use a tubing bender the type with wheels.
"It ain't a truck if you can't hose out the cab."
#57828 03/17/2006 10:35 PM | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | The issue that I know of with copper is fatigue from bending. This can happen most when you have a copper line running from the engine to the body or frame. The engine moves independently from everything else. This can be reduced by making coils that take up the movement. After time cracks can appear and then you have a failure. My 1960 Austin Healey Sprite has had copper fuel lines since new and they are still fine. I used copper on my rebuild of my 1940 1/2 ton. Go to my web site and look around on the current progress. I have pictures of my engine with copper fuel, vacumn and water heat for the intake manifold. | | |
#57829 03/18/2006 12:47 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | bill's right we have made copper lines on old motocycles and incorperated a full 'loop' to give a bit of spring/flex to the otherwise rigid line.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#57830 03/18/2006 2:10 AM | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | My '31 Olds uses copper from the fuel pump to the carb. I replaced the original lie because it had chafed against the block. The vacuum line for the wipers is also copper and has a full turn loop between the intake manifold and poit where the line is secured to the firewall. This line is original and shows no sign of fatigue after 75 years of use. So, if you like copper, use it. Just watch where and how you route it. | | |
#57831 03/18/2006 4:23 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Many things have used it for fuel lines before. But now people think it is likley to crack, and that is bad if it has gas in it and is near a hot engine.
I would use regular steel or stainless myself.
I think I have heard that it may be illegal to use copper for fuel lines in some states? like you should fail an inspection if you have copper fuel lines. I am not for sure on that though. | | |
#57832 03/18/2006 4:40 AM | Joined: Apr 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 50 | I agree with with Grigg. Better to use steel or stainless lines.
As stated earlier copper tends to work-harden from vibration and then cracks can then develop. If you are running a electronic fuel injected engine then there is even more pressure inside the fuel lines (up to 80 PSI or more in some cases) increasing the chances of leaking.
Adam | | |
#57833 03/18/2006 5:10 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thats why when copper was used in any aircraft they specified a "hold down" clip at certain intervals. To keep the lines from vibrating and cracking etc..... above all else. Be safe!! | | |
#57834 03/18/2006 7:21 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I just finished re-plumbing an old Stovebolt that had plasic tubing-like you use on your swamp-cooler-for fuel line from the rear tank to the valve by the left rocker panel. It went through holes in the frame,over the frame,across the driveline,around the frame rail,through a hole in the crossmember,made a big loop ahainst the floorboards,and went across the driveline again,over the frame rail into the change over valve.(about 15 feet of tubing) Runs a TON better now. Speed | | |
#57835 03/18/2006 2:57 PM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | If the for what its worth category regarding stainless steel fuel lines:
We have been bending fuel lines for factory multiple carburetor setups for years. Some 20 years ago, we discussed making lines from stainless steel, and contacted one of the large stainless manufacturers. We were granted an interview with their engineering department. The engineers stated quite positively that this MIGHT be a very bad idea. According to the engineers, stainless flares should NEVER be bent more than 37 degrees. Automotive fuel fittings are 45 degrees. The chief engineer suggested that if we were going to make lines from stainless, that we should also make 37 degree fittings to use with the lines. We decided NOT to fabricate any lines from stainless.
I realize others are using stainless, however the above is the "skinny" from someone (the chief engineer, not me) who should know.
In 40 plus years of working on fuel systems, I have seen only one failure of a copper line. This occured at the flare (cracked). Subsequent inspection determined that the flare retaining nut had been cross-threaded at one time in its life, which damaged the flare.
However, for "hot rod" applications, we use either steel or aluminum at the customers discretion. We use copper for the Oldsmobile J-2 tripower as that was original, and have had zero problems.
#57836 03/19/2006 12:30 AM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 |
#57837 03/19/2006 12:55 AM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I also have used copper fuel supply lines without a problem.I double flare the ends and always use new fittings.If you want a chrome look, you can use a free standing bathroom sink supply line purchased at Home Depot or a good plumbing store.Looks good and will bend up well.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#57838 03/19/2006 12:48 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | Fatigue? Many air brake trucks/buses used copper air lines until they were replaced by plastic lines in the 80's.Flex or rubber hoses are used at area of movement,compressor and brake chambers. | | |
#57839 03/19/2006 4:17 PM | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Don't know about air brake lines, but I would bet regular brake lines are probably copper/nickel lines. I used them on my 1940's brake lines. I ordered the coils online and bent the lines my self. They are very popular in Europe and again my Austin Healey used them from new. They clean up and shine like gold. If anyone is interested I can supply the link. I'll have to dredge it up. | | |
