9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible),
43
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Hey guys,
I searched this topic and didn't come up with anything. I want to start my '60 235 c.i. motor before putting it in my truck. I had an old camaro subframe so I mounted the engine in that for a good stable base. What should the electrical hookup be on this? I was told the following: pos. battery terminal to starter post, neg. battery post grounded to block, then a 10 or 12 guage wire from pos. side of battery to pos. side of coil. Then arc the terminals on the starter to turn over the engine. This correct? If not..what is the correct way to SAFELY do this? Thanks guys! | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | arcing the terminals with a screwdriver is an acceptable emergency technic, but it burns the threads/nuts. get a remote starter switch from a suppy house. they usually come in timing kits. and they're much handier when doing comp tests/ 'bumping' the starter and for adjusting valves | | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Thanks for the info....I actually have a starter switch in the garage. How are those hooked up? I have a black and red teminal with alligator clips. Just wondering where each goes. THanks. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | how about a ballast resister for the power supply going to the coil? | | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | For general start ups, a remote switch on the starter is just fine. No ballast required on the points. If this is a rebuild, you want it to start asap so all the voltage you can give it is better. I start all my engines before sending them out. I have a test stand made just for it. Don't forget the oil gauge, and temp gauge. Use a garden hose hooked to the heater hose inlet, you can vary the water flow according to how hot the water is coming out the top of the thermostat if you are not using a radiator. engine will set dead solid when running due to no torque against the flywheel. You can set then on tires and fire it right up. Its pretty cool how fast the rev with out transmission on them!
1) You need (+) to the the coil, aligator clip leads work for this
2) You need (+) and (-) to starter, large cables for this, (-) to starter bolt is ok
3) aligator clip leads with push button for starter, one lead to (+) on batt, and one to the (S) terminal on the starter.
Joe
| | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Thanks for the help! One question...though...I run both positive and negative to the starter? Positive goes to the terminal bolt as usual...Negative goes where? I just wanna get this right! Thanks again! We'll see how she runs real soon! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Negative goes to the mount bolts of the starter, or the manifold, or the block.
When you start it, don't over rev the engine without a load. | | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | | | |
