11 members (David Bush, msmall, Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9), 105 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#576961 09/22/2009 11:40 PM
I have a 58 3200 apache that has that warn in look. I like the faded paint for the body, but I would like to put a fresh coat on the headlight buckets, grill and front bumper.
http://tinypic.com/m/5a0tgw/1
Has anyone had solid results from a rattle can? I'd like to do a coat of etching or epoxy primer & then the original Ivory color.
Can I even get etching or epoxy in a can? Or for that matter the original Ivory color?
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
Ex Hall Monitor
Ex Hall Monitor
I consider rattle can paint to be inferior quality. It's OK for small parts that don't need a high quality finish.
Tiny #576987 09/23/2009 12:37 AM
to answer your question about self-etching primer in a can:yes
some thing I've done on my truck is spray clear coat[also in cans]over the colour[Canadian spelling :D]
Rattle can paint is not very hard,so it marks easy
BC52 #577092 09/23/2009 3:27 AM
Hmmm - That is what I was thinking about the cans - I've done a couple of rattle can jeeps & I've even painted one for real with a base / clear - it turned out really nice.
I'm hoping not to get too involved in this for just a bumper and grill, but then again - I don't want it to look like crap in 6 months either.
If I could find a good hard finish in a can I'd jump on it. If not - I'll bite the bullet & buy the good stuff.
bone stock 235
53k miles
3 on the tree
... rustoleum in a quart can???
I guess I could thin that down a little & shoot it through my paint gun. I know they make a good enamel that will dry nice & hard. It would need to have a good primer though - I've used that on an old trailer of mine (brushed on) and it is peeling off now.
Anyone know of a good automotive primer in a can?
bone stock 235
53k miles
3 on the tree
Most will say use expoxy primer. IF on small stuff I use either the self etching primer by duplicolor or the Automotive Primer in a can made by Rustoleum. Depends on how long you want it to stay in primer.
I've used the green self-etching primer. It's good stuff, gets good n' hard, sticks well. Kinda pricey though. I get it at Napa
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
Check it out!
Before
http://i32.tinypic.com/34pma7m.jpg
After
http://i33.tinypic.com/2vmts1x.jpg
Still just a rattle can paint job - but I think it turned out OK.
bone stock 235
53k miles
3 on the tree
Very nice! Let's here it for the rattle can! I painted my entire truck that way and then drove it to the body shop to be painted, once it was on the road.
1951 1 Ton Completed
John Deere Blitz black! is the answer You seek!!
Fine job. You did your truck justice. You weren't out for concourse. It is a big improvement of what you had and cleans it up.
A lot of bang for your buck, or loonie, or ice cubes.
(Welcome 48Ratfink)
TxLaTx #583773 10/16/2009 7:45 AM
Nice job....as others have said rattle cans are fine for smaller areas.
Like all bodywork/paint,preparation is everything.
I've rattle canned my whole dash and I'm pleased with results,time will tell......
More pix on Flickr.
Apprentice
Apprentice
Man, that looks really nice! What products did you end up using?
