| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 34 New Guy | | New Guy Joined: May 2008 Posts: 34 | In order to blast and paint the frame, would you want to remove both axles and leaf springs or leave the axles and springs intact for this process.
The best things in life are FREE!
| | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | Anything that moves will get sand in it when you blast. I would take the springs and axles out. Unless you want to replace everything anyway, expect abrasive to get into everything that has a grease fitting. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I took the springs and axles off mine too. I'm planning to replace the front and rear shackles anyway. Never know if the springs are cracked unless you take em off. Plus, taking the rear axle off will prevent any sand gettin' in the vent. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ..... Since I intended to pull the axle's to replace the torque tube with a later pumpkin and put in new grease grease seals and doing the brake job, I blasted mine with the rear end on it. Then I pulled the torque tube and flushed everything. I also left the front axle on it as I was pulling everything off the front spindle as well. So, I guess it would depend on what your "next move" is planned to be. Each situations may very.
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Sand will get into seals and destroy them. I wire-wheeled my axles and taped up the seals to keep debris out. | | |
