0 members (), 107 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
#57629 03/11/2006 5:40 AM
My brother is putting a 292 six in his 68 chevy 3/4 ton that had a bad 327 SB in it,
he has it all bolted in but now has majour clearnce issues in front, The fan will not fit becuse the water pump is about 1" away from Radiator.
Did the factory six cylinder trucks use the 4x4 moter mounting holes?
would electric Fans work in front of Radiator?
thanks Luke
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#57630 03/11/2006 12:23 PM
Electric pusher works on my AD
http://www.chuckthetruck.com/Page26.html
#57631 03/13/2006 8:51 AM
I also had an electric on my truck at one time, but went back to mechanical fan. It worked fine but I thought simple was better. Mine's a 1 ton and in a 59. I am about to put a 230 in a 72 which is the same length. Be interested to see if that's going to be a problem on this truck. Engine came from a camero.
#57632 03/13/2006 9:24 PM
knuckle head
knuckle head
It's no problem if you use the correct motor mounts,except the motor sits back some,creating a need for the shorter driveshaft used on 6's And maybe clutch linkage issues if it's a stick.
Being that Chevy V-8's are so plentiful,might have been easier to stay with the 8.
