| | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57629 03/11/2006 5:40 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | My brother is putting a 292 six in his 68 chevy 3/4 ton that had a bad 327 SB in it, he has it all bolted in but now has majour clearnce issues in front, The fan will not fit becuse the water pump is about 1" away from Radiator.
Did the factory six cylinder trucks use the 4x4 moter mounting holes? would electric Fans work in front of Radiator? thanks Luke | | |
#57630 03/11/2006 12:23 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#57631 03/13/2006 8:51 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I also had an electric on my truck at one time, but went back to mechanical fan. It worked fine but I thought simple was better. Mine's a 1 ton and in a 59. I am about to put a 230 in a 72 which is the same length. Be interested to see if that's going to be a problem on this truck. Engine came from a camero. | | |
#57632 03/13/2006 9:24 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | It's no problem if you use the correct motor mounts,except the motor sits back some,creating a need for the shorter driveshaft used on 6's And maybe clutch linkage issues if it's a stick. Being that Chevy V-8's are so plentiful,might have been easier to stay with the 8. | | |
