8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#576285 09/21/2009 2:40 AM
In order to blast and paint the frame, would you want to remove both axles and leaf springs or leave the axles and springs intact for this process.
The best things in life are FREE!
Anything that moves will get sand in it when you blast. I would take the springs and axles out. Unless you want to replace everything anyway, expect abrasive to get into everything that has a grease fitting.
I took the springs and axles off mine too. I'm planning to replace the front and rear shackles anyway. Never know if the springs are cracked unless you take em off. Plus, taking the rear axle off will prevent any sand gettin' in the vent.
..... Since I intended to pull the axle's to replace the torque tube with a later pumpkin and put in new grease grease seals and doing the brake job, I blasted mine with the rear end on it. Then I pulled the torque tube and flushed everything. I also left the front axle on it as I was pulling everything off the front spindle as well.
So, I guess it would depend on what your "next move" is planned to be. Each situations may very.
Sand will get into seals and destroy them. I wire-wheeled my axles and taped up the seals to keep debris out.
