8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57568 03/09/2006 4:00 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have a 12 bolt gm rearend that i am going to place in my 1951 chevy truck. If i have to replace the perches on it,what degree of angle should the rearend be set at,yoke,driveshaft to transmission? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#57569 03/09/2006 4:30 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The same angle as what the transmission tailshaft sits at, plus or minus a few degrees, usually plus to acount for spring deflection, Scott | | |
#57570 03/09/2006 4:37 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not sure but I think its 3 degrees positive. I am about to "lower" my pinion back down as it is defintely to high but I didn't know better back when I did it. My nephew says they use a guage of some sorts at Freightliner Chassis Co. and he may be able to help me get it right. He mentions something about checking it at the starter and tranny but it would depend on what set up you are running. I think the tranny as mentioned above would do it. I'm sure someone else will be along that can be more positive help. | | |
#57571 03/09/2006 1:16 PM | Joined: Jul 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 27 | Check out WWW.NOVAK-ADAPT.COM Go to their knowledge base, click on dirvesaft angularity. it also has a lot of transmission info as they make adapter kits for jeeps for a wide range of transmissions.
Insert clever statement here:
#57572 03/10/2006 5:09 AM | Joined: Jul 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 54 | Go to classictruckshop.com/driveline.asp | | |
#57573 03/11/2006 4:37 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Speaking of perches....I noted that one of the popular vendors sells a perch/u-bolt/shock mount kit for $139. I checked out the local trailer repair shop and scored the u-bolts, bottom plate, and 1-3/4 wide perches (new) for $20 retail. This does not include the shock mounts but from what I've heard you have to adjust to match your new diff. Mine with outboard discs would have required I modify anyways. Just a thought.....my $.02.
Dave | | |
#57575 03/16/2006 2:05 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Thanks,i have been reading some articles on the subject. I just want to make sure i do this correct the first time.I will take a look at the link you provided.
You say the 2.5" offset looks better than the 1.5" ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#57576 03/16/2006 2:10 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | yes. once you get it mocked up per the kit (if you use that)and many do cause it's easier, just move it back one more inch and snug up the U bolts. take a view and you can decide. you know measure three times cut/tack weld once. sit on looking at it overnight w/ a fresh unobsturcted side view in the morning. you have to have a new driveline made anyway http://local.sacramento.com/sacramento/Auto-Parts-~26-Supplies---New/drivelineserviceofsacramento_3713332--drive-line-service-of-sacramento.zp.html http://www.iedls.com/measure.html http://www.drive-lines.com/ so what the hay. good luck
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#57577 03/17/2006 11:43 AM | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | You can turn your springs around and you will have correct offset.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
#57578 03/17/2006 3:55 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
#57579 03/17/2006 9:33 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | I have heard many say this, but have never seen it done. On torque tube rear springs supposedly if you flip the springs (and obviously switch the bushing and shackle piece) the axle pin will center in the wheel well so as to avoid having to offset the spring perch hole. Do remember however, that the stock look is to have the rear wheels sit somewhat forward from center of the wheel well. Steve O | | |
#57580 03/18/2006 9:50 AM | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | I tried the old "turn the leaf springs around" trick and it didn't work for me - the rear axle ended up being about 1" too far BACK in the wheel well opening. Here's a pic of it before I got the bed on and realized that it was too far back: http://i48.photobucket.com/albums/f214/tkeahi/novarear015.jpg I ended up taking the rear end back off and drilling new holes in the spring perches where I wanted them. Some good advice (that I wish I followed) is to drill holes about 1" apart in your axle perches/bottom plates before you put them on so that you can tweak the location once you've got everything back together. | | |
#57581 03/21/2006 8:26 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | why KEEP that old crap buy a modern rear end and you will be better off for it. Better brakes better drive ratios.
