1 members (Dusty53),
174
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I've got a 1952 GMC 3/4 ton with a 355 (0.030" overbored 350) with 10:1 compression and an Isky 270Megacam hyd flat tappet. It's got 1986 Corvette shorty headers and 2.5 inch mandrel bent dual pipes with side exhaust in front of the rear tires. Still working out the bugs though, but it's quick with 4.56 gearing...a little too quick. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If I have a 4 cylinder but it's two cycle.. Is it like an 8 cylinder 4 cycle? Suppose it runs like a straight 8 and not a bent 8 though..
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I agree on the Atlas engines, however the thread is about V8's
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I have a 74 truck 350 in my 52 sedan  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I have one also. 1995 corvette lt1. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | 283 on one and 327 in the other.
| | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | I have a 305 in my 1946 chevy p/u.
Hotrod Lincoln helped me by good advice to make it a super v8
Cheers
Jan | | | | | Joined: Nov 2008 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 104 | I have a 72 stock 350 out of a pickup in my 53 | | | | | Joined: Dec 2008 Posts: 11 New Guy | | New Guy Joined: Dec 2008 Posts: 11 | all my v8s are on the floor of my shed
6ers power every thing I drive
60 Apache 4X4 235 67 C20 292 90 Dodge W250 Cummins
| | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | I'm working with a Mr. Goodwrench 350 in my 47 in progress. Martin | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | BBC in my Chevelle Stovebolt 6 in my '53 | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | mine will be small block powered when I build it
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | i have a mild 350 smallblock in my 65 stepside.sounds good and goes like snot. | | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | I've got a 327 in my '51 Bored out 60 new rods and pistons. Crank turned and balanced. Double roller timing set. New cam, lifters, Highrise intake and 4 Bl carb from Edelbrock performer series. Double hump heads with new valve springs and valves 2.02 + 1.6 I'm hoping to get about 350 hp out of it.
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one. -Ralph Waldo Emerson-
| | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | My '50 truck has an early 350 motor with Camel hump heads, high rise manifold and Holley four barrel carb. Pics are on my website.
Stuart. | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | fuel injected 5.3 from a 2006 Tahoe in my 50 | | | | | Joined: May 2008 Posts: 194 Shop Shark | | Shop Shark Joined: May 2008 Posts: 194 | I have a 57 3100 that was an orignal V8.
I currently has a slightly newer 60's vintage 283 in it. Not sure from what year but does not look original.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 59 poncho 389 in my 59 GMC. The motor has been bored .030 over and stroked 1/2 inch with a eagle forged stroker crank to come up with 447 inches. I am also running an early tripower on this motor. This motor is a direct bolt in replacement for the original 336 inch pontiac v8 that the gmc was born with.
I hate automatics, so this one moves with a 5 speed nv4500. I hope to break the new engine in very soon. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | By now you must have guessed that most of us changed over if we had a 6.(not that there is anything wrong with that)  | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | 1980 350/350 combo in my 57.
leonard | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I feel like V8's are pretty commonplace. The oddity is a V8 with a stock frontend. My '59 half ton still has the straight axle underneath the 350 V8. John I'll always have a straight axle under mine... | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | LT1 Corvette 350 in mine. | | | | | Joined: Jun 2009 Posts: 15 New Guy | | New Guy Joined: Jun 2009 Posts: 15 | Hi, new to the forum here. I have a 61 long bed, started life as a 6/3 on the tree model. Pops put a 327/350 combo at first, since then it's had a blown 327 and an LT1 350/400. I plan to put a gallery page up soon with pics and history, as the truck has been in my family since the mid 60's.
Wenco Ind. Driveshafts VAn Nuys, CA Est. 1967
| | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | i left the straight axle on mine, drives, rides and handles fine | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I've got a Chevy 350 small block, mildly built up, with Corvette headers and side-exit exhaust, shifted through the original transmission and differential in a 1952 GMC 3/4 ton pick up.
I love the torque, but now it accelerates a lot quicker than it will stop on the stock brakes. Future plans include a 6V53 roots supercharger off of a Detroit Diesel. But only if I can make stopping and handling safer.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Tim (the toolman) Taylor would be proud of you all!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2008 Posts: 23 Apprentice | | Apprentice Joined: Dec 2008 Posts: 23 | Fixing to put a 550hp 400 small block into my 46 1.5 ton. Though many stay old school with 216's which is cool but mine was drive train free when i got it so now its gonna be a badass 4x4 when its done. U are definitely not an oddball.
EMS is my life. But I have found my TRUE PASSION OLD TRUCKS...
| | | | | Joined: Mar 2009 Posts: 15 New Guy | | New Guy Joined: Mar 2009 Posts: 15 | | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have an early corvette, a 235 6 with 2 single barrels. lol
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 66 | My 70' GMC 1500 had a stock 350 in it with a 350 turbo hydramatic tranny behind it, but early on in it's life the stock 350 was blown. it being a workhorse got a replacement quick. It was refitted with a 350 hodge podge motor. It is a combination of the stock engine and a Target Master Motor. It still runs like a top, if you get it started. I can tell the different engines by the colors, the stock stuff is orange and the other is blue. It really is a strange looking sight. I am set to have the engine out by the end of the month for a rebuild. I plan on painting it all orange again, and when it's all set and done, it'll have 325 hp. The turbo-hydramatic is still kicking after a reseal job, but if it dies, I'd consider a manual tranny for fun. Original rear-end easily does 70 to 75 down the freeway, or at least it did when dad and I drove it home.
"So this year, I am upgraging my policy of zero tolerance to one of SUB-zero tolerance, which is MORE than zero." -Principal Jindraike
| | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | I am planning on building a 427 chevy big block with a dual carb tunnel ram. Th 400 trans. I don't know too much about the engine specs although I do know I have steel heads. I would like to get aluminum but cash is tight so I am using what I got. | | | | | Joined: Sep 2008 Posts: 24 Apprentice | | Apprentice Joined: Sep 2008 Posts: 24 | I am planning on putting a Cadillac 390ci in my 50 AD truck | | | | | Joined: Aug 2009 Posts: 16 New Guy | | New Guy Joined: Aug 2009 Posts: 16 | Man that sounds like a sweet motor I love PONTIACS I have a few around here A 69 400 that is going to to have a 65 tri power installed on it and A 455 thats set to be bored 70 over and a stroker crank to make it almost 500 cubic inch. And last but not least A 428 in my 69 GTO.... 59 poncho 389 in my 59 GMC. The motor has been bored .030 over and stroked 1/2 inch with a eagle forged stroker crank to come up with 447 inches. I am also running an early tripower on this motor. This motor is a direct bolt in replacement for the original 336 inch pontiac v8 that the gmc was born with.
| | | | | Joined: Aug 2009 Posts: 16 New Guy | | New Guy Joined: Aug 2009 Posts: 16 | My wifes 66 has a 383 putting out just about 427 phonies with a bulit just for it turbo 350. Hopefully the some of the pics of her truck will be posted in the Gallery... And hopefully by this spring the whole truck should be together.. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | 66chevyc10....Whadya mean Just 427 ponies!!  Sounds like a recipe for fun! I wonder how many HP there is in this thread? A few thousand I would guess.....  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | I have a 454 from a 72 suburban in my 51 GMC, the picture here is of the engine compartment it is a little dirty but it is in progress.
| | | | | Joined: Sep 2007 Posts: 4 New Guy | | New Guy Joined: Sep 2007 Posts: 4 | I have a "79" 350 4/bolt main with a 700R tranny that will be going in my 53 pickup. The engine came out a "BigTen" camper special my Dad bought new in 79 the engine started using oil at 80K miles and has been sitting in my shop ever since waiting on a rebuild. Engine rebuild parts are arriving and action on the truck and drive train will begin soon ! | | | | | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | My 46 1/2 ton has a 283/350. Purrs like a kitten. Rick  | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | i have a 400 in my 55-2 bored balanced- headers some head work-350 at /subframed tw-pb -pb- cam-intake. | | |
