5 members (Hotrod Lincoln, Hanks custodian, Gdads51, Gray_Ghost, Maybellene), 80 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#575181 09/17/2009 5:20 PM
Thinking about changing my '51's 216 to a 235, or 261. Will both of these engines bolt right up using the existing mounts/locations from the 216, or are there some modifications/fabrication involved in the switch.
Also, is one engine better than the other as far as fit, performance, reliability, etc. Blocks the same (?)
May take on the project over the winter, just wanting to get as much info as possible before starting.
Any info would be appreciated,
Use the search engine and look in the Tech Tips for some good information.
The 216 and early 235 is pretty near the same as are the later 235 and 261. And yes,they all bolt up with minimal modification and effort.As Brad says,there is plenty of info in the Tech Tips.
Drew
Ex Hall Monitor
Ex Hall Monitor
Check your title to see if the engine number is used as the VIN. If so, when you replace the engine without re-titling, you won't have your VIN anywhere on your truck. Just an FYI.
Call Patricks and ask for their catalogue it has a great article on the swap as well.
www.patricksantiquecars.com
Hank
1951 restoration on website
http://www.hanklong.com
Front mount plate can be swapped from your old 216 to either the 235 or 261. The other issue easily solved is with the later motors different style water pump, the Patrick's catalog deals with that issue. Like Hankdogg said, this catalog from Patrick has all the tech info you'll need.
1946 1/2-Ton Chevy
Thanks for the info.
Catalogue is on order!
The 261 is a more powerful motor but some of the parts cost more.
1951 1 Ton Completed
