4 members (1955 1 Series, 49choptop, 3800GUY, Shade Baby), 99 guests, and 0 robots.
Topics128,110
Posts1,056,274
Members48,439
#57348 03/04/2006 2:34 AM
Junior Member
Junior Member
When I took off the driver's side head on my '67 GMC 1/2ton, there was (what seemed to be) coolant in one of the cylinders. Is that possible and if so, does that suggest a bigger problem than just replacing the head gasket?
It probably got in there as you pulled the head. You could have the head magnafluxed and checked with a true bar for a piece of mind, which I recommend,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Ex Hall Monitor
Ex Hall Monitor
I can think of three posible problems. Bad head gasket, cracked head, cracked block. Hopefully it's the gasket. Good luck.
Was it acting up when you took it apart? What did the plug from that cylinder look like?
It is almost impossible to pull the head without some coolant pouring into a cylinder. If you really suspect that, the plug should look very different from the rest. In addition unless you had a huge hole in the cylinder wall, you would not find accumulated coolant, even on one with a leak.
1951 1 Ton Completed
I have yet to pull a head with off spilling coolant. If the motor wasn't blowing white smoke I wouldn't worry to much and if it was it's probably the gasket. Unless you over heated it or froze the block you shouldn't have a crack.
New deal for old steel
did it blow a little white smoke out the exhaust b4 you pulled it apart. that is a sing of H2O in the cylinder.
Jim & Caroline
Junior Member
Junior Member
Actually, I've haven't run the engine yet at all. I've got almost all of it back together again and am hoping to starter it up next week. I guess we'll find out then!
Thanks for your help guys,
