| | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57348 03/04/2006 2:34 AM | Joined: Apr 2005 Posts: 10 Junior Member | | Junior Member Joined: Apr 2005 Posts: 10 | When I took off the driver's side head on my '67 GMC 1/2ton, there was (what seemed to be) coolant in one of the cylinders. Is that possible and if so, does that suggest a bigger problem than just replacing the head gasket?
R | | |
#57349 03/04/2006 3:34 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It probably got in there as you pulled the head. You could have the head magnafluxed and checked with a true bar for a piece of mind, which I recommend, Scott | | |
#57350 03/04/2006 4:10 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I can think of three posible problems. Bad head gasket, cracked head, cracked block. Hopefully it's the gasket. Good luck.
#57351 03/04/2006 4:46 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Was it acting up when you took it apart? What did the plug from that cylinder look like? | | |
#57352 03/04/2006 5:56 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It is almost impossible to pull the head without some coolant pouring into a cylinder. If you really suspect that, the plug should look very different from the rest. In addition unless you had a huge hole in the cylinder wall, you would not find accumulated coolant, even on one with a leak. | | |
#57353 03/04/2006 9:35 PM | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | I have yet to pull a head with off spilling coolant. If the motor wasn't blowing white smoke I wouldn't worry to much and if it was it's probably the gasket. Unless you over heated it or froze the block you shouldn't have a crack.
New deal for old steel
#57354 03/09/2006 1:18 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | did it blow a little white smoke out the exhaust b4 you pulled it apart. that is a sing of H2O in the cylinder.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#57355 03/10/2006 9:08 PM | Joined: Apr 2005 Posts: 10 Junior Member | | Junior Member Joined: Apr 2005 Posts: 10 | Actually, I've haven't run the engine yet at all. I've got almost all of it back together again and am hoping to starter it up next week. I guess we'll find out then!
Thanks for your help guys,
R | | |
