4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#573072 09/10/2009 4:27 PM
Who would be the "Go to Guy", if there is one, when it comes to rebuilding a Zenith carb off of a 52 or 53 GMC COE?
Glory Bound...
The updraft carbs have only about a dozen parts. You could easily rebuild this yourself, the only adjustment being the float height and where the clip sits on the piston inside.
Im sure I could come up with the measurements for the float if you need. You can spend $40 on a kit, but the only replacable parts are a needle/seat and a gasket. Maybe a small spring or two. These really are about as simple as carbs come.
Jeff
My 1953 Chevrolet
1947.1 Gallery
And where can i get the kit?
Glory Bound...
If your local parts store cant get you one, try here.
http://www.thecarburetorshop.com/
Or, Jim Carters has them.
My 1953 Chevrolet
1947.1 Gallery
