8 members (3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, Joe H, Joe Lowe III, 1 invisible),
77
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Who would be the "Go to Guy", if there is one, when it comes to rebuilding a Zenith carb off of a 52 or 53 GMC COE?
Glory Bound...
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The updraft carbs have only about a dozen parts. You could easily rebuild this yourself, the only adjustment being the float height and where the clip sits on the piston inside.
Im sure I could come up with the measurements for the float if you need. You can spend $40 on a kit, but the only replacable parts are a needle/seat and a gasket. Maybe a small spring or two. These really are about as simple as carbs come.
Jeff | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | And where can i get the kit?
Glory Bound...
