9 members (Hanks custodian, Hotrod Lincoln, Ponchogl, Otto Skorzeny, Bill Hanlon, Charles in CA, 48ed56pam, Bill Marlow, frogfarmer), 177 guests, and 1 robot.
Topics128,081
Posts1,056,071
Members48,434
#573072 09/10/2009 4:27 PM
Who would be the "Go to Guy", if there is one, when it comes to rebuilding a Zenith carb off of a 52 or 53 GMC COE?
Glory Bound...
The updraft carbs have only about a dozen parts. You could easily rebuild this yourself, the only adjustment being the float height and where the clip sits on the piston inside.
Im sure I could come up with the measurements for the float if you need. You can spend $40 on a kit, but the only replacable parts are a needle/seat and a gasket. Maybe a small spring or two. These really are about as simple as carbs come.
Jeff
My 1953 Chevrolet
1947.1 Gallery
And where can i get the kit?
Glory Bound...
If your local parts store cant get you one, try here.
http://www.thecarburetorshop.com/
Or, Jim Carters has them.
My 1953 Chevrolet
1947.1 Gallery
