1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#572473 09/08/2009 3:22 PM
on my 52 when i close the hood the hood comes up were it pivots in the back , i loosened the 3 bolts on either side and pushed it flat and tightened them, looked good, until i opened the hood and then it raises up again, are my springs funky? anyhelp would b appreciated thanks trying
trying #572495 09/08/2009 5:07 PM
Ex Hall Monitor
Ex Hall Monitor
If you can push the back of the hood down and it stays down first try oiling all pivot points. Then open and close the hood several times to spread the lubrication. I can't tell you how many "sprung" hinges I "fixed" by oiling them. If you push down on the back of the hood and it's solid (won't push down) but high it needs adjusted.
Tiny #572533 09/08/2009 6:55 PM
Hers a Tip that was posted here a while back that I used & it works great.
Open the hood and loosen your hinge bolts a bit now lay a pc. of 4X4 across your hood latch in front of the radiator, now close the hood down and let it rest on the 4X4 and push the back of the hood down onto the cowl seal and have a partner tighten up the hinge bolts.
Give that a try it should fix you problem.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Tim... I remember reading that somewhere.... probably in the tech tips... but is it a 4x4 or was it a 2x4.... I'm not being scarcastic I'm serious! I will be putting mine on a little later this year...
......but tomorrow I'm going to KC yipeeeeeee yahoo
Not trying to butt in but it is a 4 inch block of wood. That's what is in the tech tips.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
Alvin,
I used a 12" long pc. of a 4X4 that was here in the shop and it worked just fine I got a pile of em in the corner they come in handy for lots of things.
Tim
1952 Chevy Shortbed
Just to add.....the key to getting a really tight fit is to have 3 persons working in concert.
Persons 1&2 each place one hand on the top surface of the hood and the other hand on the vertical surface on both the passenger's and driver's side. With the block in place, both push down and back (with gusto) while the third person snugs down the interior bolts. With the interior bolts snug...raise the hood and tighten the remaining bolts.
Pop out the block and unless the hood has been seriously sprung, or your hinges are badly worn, she'll lay flat as a pancake. If you've got gaps between the hood and a fender, loosen the fender to core support bolts and make adjustments accordingly.
The key is to have the block, and 3 folks to get it to lay flat on the cowl. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Its a good idea to remove the latch striker plate when you are doing any hood adjustments. There have been cases where people have adjusted the hood hinges and then jammed the latch, which makes it a real pain to get loose!
Paint & Body Shop moderator
Apprentice
Apprentice
I've found on my truck that when the springs were not attached the hood laid flat against the cowl , as soon as i attached the springs it pushed the hood up in the back . It turned out that the hinges had so much slop at the pivot points that the pressure from the springs pushed the hood up . I haven't found how to fix the problem , i would like to replace the rivets in the hinge w/oversize ones . That would remove the slop. Has anyone done this repair before. Can new hinges be found ? mark
