Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#57248 03/03/2006 12:04 AM
Hey Guys,
I finished installing and bleeding the brake lines and master cylander on my '40 GMC. Problem is I cant get much response when pressing the pedal unless I pump the pedal. I have bled the lines and can see no problem there. The system has a new rebuilt single cylander master. What am I doing wrong or is this typicle of these systems?
G. Lee
#57249 03/03/2006 12:14 AM
do you have all wheels adjusted up properly, slight drag?
#57250 03/03/2006 12:16 AM
Riding in the Passing Lane
When these brakes are right there is practically no movement on the brake pedal. You just apply pressure. Each wheel has 2 adjusters. They both are right hand threads so turn in opposite directions. It,s hard to understand which way to turn the starwheels unless you see a wheel cylinder. Adjust each adjustment till you get a heavy drag. Then back it up 2-4 notches. If you still have a low pedal you may still have air in the system. Make shure the pedal has a little free play before it starts pushing the master cyl. piston.
1972 Chevy c10 Cheyenne Super
#57251 03/03/2006 2:04 AM
gelee,
just chiming in on what red and W.B.R. said. I messed around for days until I opened the shop manual and figured out that I did not have the brakes adjusted correctly.
I adjusted as described above and they worked like a charm.
#57252 03/03/2006 2:32 AM
Sometimes when I redo a brake system, I adjust all of the brakes up tight which means BOTH shoes per wheel. Then I bleed them until the air is gone. It will give you a better idea of how much air is still in the system when you know the brakes are already to their limits. Sometimes you'll need to adjust your master to pedal linkage too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
