| | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | I have a Rochester on 55 235 that drains when sitting for a day and I have to crank the engine way too long to get it started Is the problem the pump or the carb? starts easy after that?? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm not sure of the construction of the Rochester but IMHO if you don't have fuel actually dripping out of the carb it's most likely siphoning back through the fuel pump. Do you have a glass globe fuel pump? If so is the globe full of gas before you try to start the engine? If it was only the float bowl being empty it wouldn't require too long of a crank to get it running. A long crank time indicates it's probably having to refill from the pump forward.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Also, many of these carbs have vent holes and with todays gasoline it evaporates quickly, in my experience within 1-3 days depending. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I'm not surprised. My Rochester B leaks like crazy all the time... | | |
